1 - 15 of 15 Posts
Which is more durable? That Nikasil stuff must be pretty hard
Nikasil is just a coating, you can nikasil a sleeve.
Nikasil is only good for cylinders if you use a higher grade gasoline. Cheap gasolines cause the nikasil to break down.
Cheap gas? As in only race fuel or stick with name brand premium fuel, chevron, etc.
Nikasil break down from cheap gas? What? I've seen motors wear out over two sets of pistons because of dirt yet the nikasil show almost no wear what so ever... Cylinders that you had to beat off because there was so much mud they wouldn't slide... When it comes to wear resistant I'm a believer in nikasil experience.
Gasolines high in sulfur. Cheap was the wrong word. I should have said, lower quality gasoline.
This will answer ALL your nikasil questions.
http://www.aera.org/ep/downloads/ep4/EP10-2008_18.pdf
Goatman, I never said nikasil was bad. Sulfur breaks down nikasil. That is a proven fact. For anything that you would be interested in enigma nikasil would be perfectly fine. Your question was nikasil or sleeves, and the answer is nikasil the sleeves.
Not sure how much that process costs though.
http://www.madabout-kitcars.com/kitcar/kb.php?aid=452
as for your question
haven't heard of many BF cylinders going bad
what you need BF cylinders for Enigma :eek:
He's Upgrading. :cool:
what are you rolling your eyes about
I know nothing :rolleyes:
:p
uh oh.. BUSTED.. lol
beats me.. I have a hard enough time keeping track of my own junk, much less everyone elses stuff.. :p
Mine weren't even close so they had to get Nikasil'd
1 - 15 of 15 Posts
