04' 700 Paririe 4x4....I changed the oil. Probably put in to much, and it is still just barely showing on the dip stick. I don't have a manual on it, so is there a certain way to check it.....Do you have to wait any time after turning it off to check it, or is it supposed to be looked at right away. Thanks for your help.
you dont want the oil all the way to the full mark. half way in the hash marks is perfect. if you changed the oil filter also, 2 qts will get you just about where you need to be. after you change it let it run for a few min shut it off and let it set for a few min. give the oil a chance to settle back down to the bottom end before you check it. screw the dipstick in to check it. good luck
