It is result of inadequate crankcase venting. The engine is overdue for an oil change which I will be doing in the next couple days. I may modify the dipstick as the design of it being over three feet long allows moisture to accumulate in the horizontal position across the engine compartment.There may be some vent hoses clogged somewhere also. The engine runs fine, no smoke. I try to keep the engine wound up as much as possible. It is a 2 cyl. and the mule is a 2016 4010. I will post my findings later.
