Oil in my belt case in behind my secondary coming from the seal, very little but enough to make some debris sticky any ideas on how to fix or what this is from. I installed the primary and seconday spring after I found the problem. Belt and clutches dry but back of housing and seal and bearing is a little wet. Only Modication was my belt deflection removing larger shim. I have a video on youtube for you to check out whether its a bearing or a seal I dont know much about engines. Thanks for any help or suggestions
