Has anyone seen an oil leak on a 02-03 prarie 650 behind the primary coming from the engine. We have replaced the seal 3 times, I wounder about a crank case vent? Or is there a bearing that wears?
Could be leaking from around the intermediate shaft cover. Behind your clutch there is a small round cover with a 6mm bolt hole in the middle of it. Thread a bolt in and wiggle it and it should come out. This has an o-ring on it that is probably damaged.
