All,
Here is my issue. I have a 2005 Brute Force 750. About 1400 miles/ 350 hours.
After I ride the atv for a few hours and it is good and hot the Oil light will sometimes consitently flash at idle. I have noticed that when I rev it up a little the light will stop flashing. I checked the Oil and it is at the correct level.
This past weekend i noticed that if the light is flashing and I messed with the speed sensor, it seemed to flash irregularly.
Is the speed sensor tied into the Oil light? Or is this just a fluke?
Thanks in advance for your help!
-Aaron
Oil sender could be bad or bad wire, take youre sender out and put a gauge in ther to see what you have when it is hot
