I recently changed the oil on my mojave and i used 10w-40 penzoil and with 10 minutes of riding it was leaking right above the kickstart. It was already a greenish milky color too. please help!
I ended up taking off the engine cover.. gaskets were put on incorrectly by the last owner so the coolant was leaking into the the oil and out of the quad. While i had it apart i wanted to check the kickstart out.. i noticed my gears were fine but i think it was the idle gear shaft ( one in between kickstart gear and one behind clutch) was snapped. I think i found one for 15 but will i have to do alot to put that in? Thanks!
I'd use some other brand than pennzoil. It's got some low ratings all over the internet.
Amsoil 10w40 4 stroke is a good choice.
