I'm putting my 2002 Mojave 250 back together (after a top end rebuild) and I noticed the oil return tubes coming down from the top of the cylinder head to the crankcase do not all have rubber gaskets inside them. There are two tubes that connect together at the top of the crankcase behind the cylinder. I looked up the parts breakdown and it doesn't show gaskets inside any of them, or at least not as a part you can buy. I would like to know if anyone knows if they should all have rubber gaskets inside them or not? I have the brass washers for the outside, just trying to figure out if they should all have the inside rubber washers or not.
Thanks
