1 - 1 of 1 Posts
FOR ANYBODY THAT'S TRIED TO CHANGE OUT YOUR OUTPUT SHAFT BEARINGS AND YOU NEED TO BUY SPECIAL KAWA TOOLS AT AROUND 325.00 HERE'S WHAT I DID ----IF YOU HAVE ACCESS TO A LATHE AND MILL ----USED SOME 1-1/2 INCH PLUMBING JOINTS AND MILLED THE 6 SIDED HEX A FEW MM TO FIT THE LARGE HEX BEARING RETAINER ---BRAISED IN A SOCKET AND WORKED LIKE A CHARM -----SAME GOES FOR THE RETAINER NUT ---CUT DOWN A 6 INCH PIECE OF 1-1/2 ---CUT THE 4 LUGS OUT ON THE END --BRAISED ON A SOCKET AND AGAIN WORKS LIKE A CHARM
Light Automotive tire Gas Kitchen appliance Auto part
Automotive tire Household hardware Gas Auto part Engineering
Cosmetics Audio equipment Gas Serveware Auto part
1 - 1 of 1 Posts
