My 4010 mule will not start relay just clicks has a new starter
Kawasaki Mule 550, KAF-300-C5
yep, the first thing i do with any electrical problem, is remove the ground cable, wire brush both ends and where they bolt too if possible, same for the positive.
then a digital multimeter comes in handy, there should be a skinny trigger wire that goes the starter, it should have the same voltage as the battery or a little less when the key is in ON and Start. check that.
