I have a 2006 prarie 360 I'm parting out: this Atv is located at my shop in meridian, ms 39301
most of these parts interchange with the prarie 650 and 700 and the brute 650:
check dealer to make sure if you don't know I know the front axels and the differintials are the same on the straight Axel models...
Seat: 100.00
plastics: 150.00
headlights: 25.00
lift kit: 50.00
4 wd actuator: 125.00
engine brake actuator: 100.00
primary clutch: 200.00
secondary clutch: 175.00
clutch cover: 50.00
front right Axel: 100.00
front diff: 250.00
rear swing arm : 300.00
front stuts and springs : 75.00
rear shock and spring: 40.00
stock exhaust: 50.00
front basket rack: 40.00
front tube rack: 30.00
rear tube rack: 45.00
front drive shaft: 50.00
rear drive shaft: 50.00
front brake calipers: 50.00 a piece
cdi box: 75.00
stock rims with used! Titan 589s : 150.00 for all 4
all prices are negotionable and if it ain't listed just ask!
Thanks
Seat: 100.00
plastics: 150.00
headlights: 25.00
lift kit: 50.00
clutch cover: 50.00
front diff: 250.00
cdi box: 75.00
Thanks
