Pc iii rev extend problem
781 Views 2 Replies 2 Participants Last post by  bansheecraig
When i put in the rev extend code, check the box and press ok, the bike will idle low and rough. It also does not want to rev. Any thoughts on this? Thanks
Yes I do. I know what you are saying, "raising rev limiter can only be done when you have both pc3 and ignition module". It raises it up 500 rpm to 8700 rpm.
I am about to do a standard bore so I need to raise the limiter to get the most out of it. I emailed Dynojet on this also and will call thier tech support this week.
