Pink Spring
1129 Views 5 Replies 6 Participants Last post by  Jim
What are the pro's and con's of the pink spring?
No cons that I can think of.
Pros are no stall (if thats what you want)
Better all around performance
worth every penny.good all around performance
Ive been running the pink spring for about a year and I think it is a good all around spring. When you hit the throttle it engages right away. I do mostly trail riding with the occasional drag race. I think it is an excellent spring for someone that does alot of trail riding. Just my two cents worth.
i like my pink epi, seems to not be as jerky when tapping throttle at low speeds
Probably the biggest seller here as a general purpose spring and recommended.
Some of the pavement guys dragging say it delivers the best top end performance and yet tame manageable out the gate.
Oval track dirt track guys swears its a must.
Gncc proven favorite also.
Works well with all weights of these bikes and any type of cut on the clutch or setup.
