If i cant find a replacement engine for my 750 brute, ill be rebuilding. I notice the pistons for sale from wiseco are 11.5 compression flat tops. Is anyone running these and is there much power difference over the stock pistons? Thanks
very little difference with just pistons
there is a huge difference if you go with a builders cams and pistons
the big gains are with the cams... the better cams you can run the better off you will be... the off the shelf wiseco's wont work with some of the builders cams... your better off finding a set of fst/fundy/amr pistons to put in your bike....
I've got a set of Fundy 750 11.5-1 pistons and trail/race cams I'm going to sell. You will need a set of kibblewhite double valve springs to run the cams. Just pulled them out of my Brute.
