i got my big gun slip on in today and was very excited to put it on...but as i was talkin the old exhaust off, one of the studs sticking out of my motor broke off inside...WHAT DO I DO??​
Drill it out with a left hand Drill, or use an EZ Out. If that Don't Work Drill and Retap it, or Heil Coil it
Weld a washer to the broken stud, then weld a nut to the washer. Back it out. Not only will the but let you use a wrench, but the heat from the washer welding will free it up.
