I have an 2003 Kawasaki prarie and the overide button is working backwards. When you are in reverse you can go full throttle and not have to use the overide button but when you are in high or low it has a limiter and you have to press the overide button to bypass the limiter just like you would in reverse but somehow it is backwards. Any suggestions will help.
