1 - 15 of 15 Posts
1)I have an 05 kfx v-force & i just complete to clean the curb' have also replaced the stock main jets & installed (F)132 (R)138, the pilot jets are 40, air mix is 2 turn out, it as a KN air filter, valves have been adjusted as per spec's,,, all the rest is stock,,,,, as I started the unit it and warmed it up,, it is been popping & backfire out of front curb',,, any suggestions ???
2) How do i re-set the belt light ???
Popping and Back Firing , Happens to me after I eat Indian Food! :eek:
Zigi--Welcome to KR---What was it doing before you did all the above work on it.
Kenny
What part of Calif---I'm out in Yucca Valley
Kenny
So it's backfiring through the carb and not the exhaust and it's just the front carb---Is that correct--Is it at idle and smooths out as you open throttle or does it do it at all ranges---Try opening that front a/f screw some more--Don't go past 3.5 turns out though--Just to experiment to see if it smooths out.
Kenny
I have a 2006 V-force with Dual HMF exhaust, K&n Filter and jets and at 1/2 throttle to full throttle it'll back fire on the back piston (right side pipe) when held and a constant speed. Help?!!?
Take your carbs out and clean them very good after disassembly. Pay close attention to the pilot jets.
Can somebody tell me where are the air mixture screws on 07 kfx700, I can only see a small brass screw in the bottom of the bowl and appears to have no tension on it. Do I have to remove the air box to access these adjustments ?
If you're carbs haven't been touched yet. They are probably still covered by the factory caps. I pulled mine off with a pair of pliers.
Dont believe they have been touched , Where are they on the side ? can you acess them easily . I cant seem to see nothing in there with the box on.
Thanx
1 - 15 of 15 Posts
