1 - 20 of 25 Posts
Is it worth the time and effort?
Do you use a dremel with a sanding drum to clean things up?
Any time you can smoothout the transition, it is going to help. At high velocity, matching up the runners will prevent turbulance. Now whether that results in seat of the pant feel, it's hard to say. But it definately can't hurt.:D
Never ground polyurethane before. I imagine it roughs up the surface vs. the smooth original popped straight out of the mold.
Best method to remove material? Dremel? Thats all I can think of?
Smoothing transitions huh :huh:. You do know that Camo is soooo sold on this practice that he even smooths and polishes his transitions on the outside of his quad, to gain speed :hehe:. Right Terry?
Well that and of course this
Sorry Terry & Tom :wub:
Remember, you do have a aluminum flange built in.
Discussion Starter · #10 ·
Is that a no no to grind? These buggers were expensive. Dont want to goof it up.
I did notice the polyurethane thickness inside the flange is uneven. Not much material to remove on the one side.
I will just have to bolt up and find out.
It makes it easier to port match..
turbulence is bad on the exhaust side, but has proven useful on the intake side up until it reduces the amount of fuel needed for the motor. I doubt in this case that it would be of much help. In Metal and Camo's case where they are packing in the A/F, it may pay off. With the exception of that, I would try to maintain the integrity of the manifold. JMHO
I humbly diagree badhear....at least with your choice of example.
AFAIK both Metal and Camo run forced induction fuel delivery systems.
Forced Induction works via pressure...a smooth transition is LESS important when you introduce pressure.
Natural Aspiration on the other hand, DEPENDS on a smooth transition because the vacuum created by the piston is the only thing drawing in air/fuel.
If an obstruction is hindering that vacuum from affecting the carb you are going to see a greater performance drop than a system that relies on pressure from a blower or turbo to deliver the air/fuel into the combustion chamber.
This is all realtive however as each setup is as different as a snowflake.
Bottom line...IMO portmatching IS a good idea no-matter N/A or F/I...
I just think you'll get more gain from a N/A application.
The problem with your theory is that the intake is smaller than the head, therefore no ridge, If the intake restricted neccessary flow, we would be on the same page. If the intake runner is bigger than necessary then you lose velocity. Turbulence to mix the fuel will create a more even burn. When you are forcing it in (blower, supercharger) volume becomes more of an issue. Right or wrong, in Enigma's application, that port work would unlikey result in 1/10th of a hp on the dyno.
In light of that I retract my disagreement.....I've never seen UPP's I thought there was a ridge.
I agree with badhear now.
Ed3
Actually Badhear GarDog is right.:p With a forced induction situation, the air fuel mix is forced in under presure and therefore the need for smooth transitions aren't as important. There is constant presure.
The kind of turbulance you are talking about is a roughness in the intake track that helps atomize fuel. That is entirely different than turbulance caused by an incease or decrease in intake size at some piont in the intake runner (Both Manifold & head).
This isn't a NEW idea. Engine builders have been doing this for years for a reason.:D
The prediction on a HP increase is probably close or maybe a little low. But hey, when races are won and lost by inches, any little bit helps.:cool:
Discussion Starter · #17 ·
I gave up on winning against you guys. I just want to be able to keep it kinda close. That giggle juice scares me.
Nothing better than a big ol sasquatch lining up against a 150 lb guy on a 450 and blowin there doors off.
Let me know what you think of it i really want to get one if $$ ever allows did you ever get your carbs figured out??
Discussion Starter · #19 ·
It will be a brand new test & tune on this setup. I guess I will throw my log book in the trash. Not familiar so I will be starting from scratch. I will definitely want a meter on this.
I polish the plastics... good for 3 mph. :hehe:
1 - 20 of 25 Posts
