I was getting ready to install my new powervalves and noticed that the lever comming up from the side case (clutch cover) was moving freely. I took the case off and put the rod back in the groove and then I moved the lever to the side up top i felt it pop out of the groove again. Am i pulling it to far? How far is it suppose to move?
Give me a call if you need help setting up the power valves. There is a small pin and screw that keep the rod sticking out of the clutch cover from sliding out. And yes, you can pull the governor rod out to far, that's why there is a guide and stopper screw.
-ORI
Thanks Greg, I found the stopper screw and i have everything figured out.
