I just put a new carb in my 360 today. The last carb was causing it to idle to high to the point where I couldn't change gears. After I got the new carb in I adjusted the idle screw and it finally started idling fine. I put it in gear and when I started to give it a lot of gas it kinda sputtered and wouldn't really go. I finally got it going but it wont get going that fast and it will start to sputter and do that until I left off the gas. When I pull the choke out it seems to run a little better, but still not 100%. Also, I added a brand new air filter today as well, and after I cut it off it smells like gas bad. If anyone has had this problem and has a answer I'd greatly appreciate it.
had some carb issues, with my fils, would spit and sputter at anything above idle. he put a new carb from ebay on it. still same. ended up being good after oem carb dipped over night and mostly new oem jets
