Cleaned CVK carb on 360. Idles nice, but rough on the way up. I did not replace the little o-ring in the idle adj screw. Would that make a big difference? I have adjusted the idle rich and lean and now it is in the middle.
No exhaust leaks and has a clean filter. Low hours. At high rpm it appears to have a miss. ( Did not change the plugs or clean them due to the low hrs.) Any advice on what and where to look will be appreciated.
Surely there must be an expert out there who knows how to tune a CVK and would like to share some insight in to this problem. Give it a try, I dare ya.
