My 2003 has been tough to put into gear and would grind a bit lately. Today when I put it in reverse it backed up a foot then I heard a strange noise and it stopped going backward. It won't go forward either and the shifter won't even move into low. I pushed it back in the barn and need help. Thanks.
Is there a possibility that the belt may have broken? The alternatives will be much more costly.
Thanks, is it easy to check for a broken belt?
Take the belt housing exhaust duct off (right-hand side, a little behind the engine brake servo, takes a phillips screwdriver to loosen the clamp) and look down inside. You will see the belt down through the opening.
