got a 2000 prairie 400, that will only run about 10 mph in hi or low.
the motor is running great and seams like it wont come out of first gear, also i have to hit the gas a couple of times before it will start to move.
i pulled the belt cover off to see if the belt was slipping and its not.
so in nutrile with the cover off i started it and gave it some gas, and the belt will run up the drive pully like its supposed to i assume. so i jacked up the rear tires, put it in gear and did the same thing. again the belt runs up the drive pully as it narrows when the speed increases. i dont know how much play is supposed to be in the belt or if it is worn.
so any advise on this issue would be much appriciated.
