I have a prairie 400 with Motosport 14 in wheels and 26 in Moto MTCs i would like to know the best clutch spring setup for this kind of tires it seems like mine just doesnt wanna get up and go like it should..... i dont wanna do any mods now just springs or a good setup for it ... let me know what u guys think?
Not a lot of info out there on the P400, although it's a great machine. The spring tension can be adjusted in the secondary clutch; you just move the spring to a different hole, I believe there are 3 holes. The holes that put more tension on the spring will raise the RPM's and give you back some of the power that was lost with the bigger/heavier tires.
Alright man thanks and also would it be a good idea to put a comet clutch in or just mess with the stock one or epi clutch kit?
The Comet is merely a replacement; if the stock clutch isn't worn out then there's no advantage.
