I split my front diff today and found that the bearings on my pinion are shot... I was wondering what the trick is to remove the pinion and bearings to replace!
There is a special socket from kawi.When I bought mine a few years ago it was around seventy dollars.Some people on here are taking a socket and grinding flats on the outside to remove the retainer.Then there is a nut on the pinion to remove the bearing.
This the one I made...$10 at Oreilly's and 30min grinding. After I got the pinion gear out, I put it in a vise and used the same socket with an impact to get the nut off. I think the Kawie tool is about $200.
