Hey yall I've had about enough of this thing... I have an 04 prairie 700 ( really a suzuki twin peaks) the oil pump blew up on it and until then it was running great I had just rebuilt the carb before hand. Afterwards I spun a bearing and rebuilt the motor (crank pistons rods bearings seals) all new I got good used heads with cams from a local salvage yard. After the rebuild it was running ok but felt like it was stumbling on itself so I took it to getbthe carbs synced. The shop said I had a valve issue so I replaced them now it pops and back fires under load. I just did a leak down test the Guage isn't reading any significant leaking but there is a slight hiss from the dip stick tube I'm pretty fed up with this thing and any help would be appreciated
