1 - 11 of 11 Posts
Getting ready to do the 20 HR service on my Pro FXT. What oil do you guys use and what gear oil for transmission and front gear case?
Be prepared if you are doing your own first oil change. The filter is extremely tight. Very small diameter filter I tried several different wrenches including the cap type using a ratchet wrench. Could not budge it. Called my local dealer he said it was typical with filters being overly tight from factory. I gave up made appointment to get oil changed.
Engine oil should be a JASO MA-2 certified oil, per kawasaki.
I use Castrol GO! 4T 10w-40, & a Wix 51394 filter.
Just did 120 mile service. I bought oil change kit from local dealer. Only $28 for oil, filter, crush washer. This is a factory kit.
The reason for my post is to make anyone doing this aware of what I found on the rear diff/transmission. When I pulled the drain plug it was obviously under pressure and gear oil spewed out. Changed gear oil and then investigated why there was pressure. I found where the vent tube went up and then down into frame it was kinked in an S curve not allowing diff to vent. I could look up with light in frame and see kink. I pulled it out and clipped it off so it could vent pressure. Hopefully this pressure has not already compromised a seal. I don't see any leaks at this point.
What is the crush washer? I’m about to do my 20 hr service.
The crush washer is a copper washer on drain plug. I have reused these on other machines with no problem, but it does give a little peace of mind to have a new one.
Another note on my 120 mile service. I have the Ranch model with factory installed winch. I was able to just remove the aluminum plate in front of winch that is held with 4 phillips head screws to access fill plug on front differential. Much easier than removing bumper.
Gotcha. Thanks. I didn’t know if it was for the filter. I’d be fine re-using it if it looks ok.
1 - 11 of 11 Posts
