1 - 20 of 116 Posts
dang metal.....:huh:, what the heck did you do to it?
couldn't find the other thread
not sure where, just remember reading something on my phone.....driving 200 miles a day, it helps kill some time
I did read you're going to Brute cases
probably wise choice since you're now making more ponies. You did get a lot of use and abuse out of your original cases
OUCH!!!! I thought you cracked the frame....:( THAT SUCKS
Man, that is a good one. You start a shelf for all your torn up parts?
he mounts em to teak and mahogany pieces and puts little plaquetes on em to keep as trophys!
crack like that makes me think that it is torque stress related from launching that hard. I saw your vids and that comes out of the hole hard as hell.
when you split the cases I want to see what happened inside. if it doesn't extend down from the bronze bushing timing had nothing to due with it. it was just torque twisting power.
comments like that make me wanna take that beast for a ride.
all that torque makes me wonder what the power to weight ratio is??????
Discussion Starter · #13 · (Edited)
JOHN, if I order cases off ebay and the left side bearings are bad, are those replaceable? I don't want to order until I find that out.
Chaos hell if I know. :)
Zmann
1 set cracked cases
1 broken piston
1 set of heads with a hole burned through them (repaired)
1 set of sleeved 840 cylinders that are useless for a power adder (head gaskets)
1 clutch that was damn near cracked in half (john has that)
1 clutch that blew the spider apart (john has that too)
I think that is it. :)
start a trophy shelf... got to get a good sized pile going it sounds like.. :p
Good old part breakin raw blower power there and some good reading, Smokey would be proud Erick :lol:.
Damn!:lol:
Nice work metal.
You think it will be back together by President"s Day? I would like to see that quad in person sometime at Dumont (seen lots of videos of it).
1 - 20 of 116 Posts
