1 - 14 of 14 Posts
Rear brake problem
OK i have 06 V and my rear brakes are not fictional at all
any time i tight them more it is ether my bike is tight like it is on perking brake and still no brakes wile I'm driving at all
is it normal or i have to change them and is it hart to do that ???????
man i cant spell at all and I'm tellin u please go back to english class.
OK i will
but I'm not at English class right now I'm at kawieriders forum it is not about English it is about V Force that we discus hear but thank you for reply
Quick question - have you ever changed the fluid in the rear end? If so, did you use wet brake fluid to refill it? Using regular rear end fluid really messes up the brakes.
also you need to adjust both the foot and hand brake properly
Monkey is there a good place to find this? My hand brake works great but the foot brake sucks. Better luck putting my feet on the ground like Fred Flintstone!!!
they both operate the same friction discs, you probably just need to screw in the wing nut on the rear lever that the rear foot brake cable goes to
It should be covered in the operators manual.....sorry kinda busy or I'd give the factory procedure
Discussion Starter #8
yes i did and now i have a gear oil in it
so wot is the right oil that i need to use in rear end :confused:???????
your discs are probably shot
wet brake compatible hydraulic fluid
Hydraulic fluid suitable for wet clutches or brakes.
Yep your friction discs a toast. Order new ones.
Discussion Starter #11
can you name any fuids that i can use ???????
Any tractor fluid suitable for wet brakes or clutches. Napa
Or if you are unsure... get the Kawasaki stuff from your dealer. You only need one quart. You'll have to change your discs first. There's no saving them.
Its probably your friction discs, mine are gone as well so they're on my to do list, I hate having no back brake because I use it a lot to set the bike up for tight turns on the trails.
They're going to cost me $42 each here :eek: don't know what they cost over there?
Discussion Starter #14 (Edited)
1 - 14 of 14 Posts
