1 - 9 of 9 Posts
the steel bracket that that holds the rear plastics on were ur heel gaurds bolts to the frame keeps breaking i go thru about 4-5 a yr anybody elses break,is there a better option?
at $48 from kawie here and a 6 week wait is a pizz of
What are you doing that keeps breaking them.I have never had to replace any.I can get those brackets here for $10.00 I guess it sucks to be living down under.
owning a kfx700 and livn down under sux because parts are bullshit for these things if i was like everybody else and owned a boring 450 or rappy
and living down under it would be perfect :lol:
oh yeah obviously i ride harder than u im breakn stuff:p
That still doesn't answer my? how do you keep breaking them?I do ride on the edge sometimes.
if i knew ide fix the problem all 3 of the kfxs have done it 2 now because i sold one
i will put up a pic its only just arond were the bolt head sits exact place eveytime ive tryed using a washer to make the surface area bigger but still the same thing happens
I've broken a few myself....tried the washer trick also....but not much luck. Lucky for me I just buy them used off ebay for a couple bucks, so i haven't spent much time trying to fix the problem.
so is it the heal guard cage? or the bracket up above that? if its the one on the heal cage just get some nerf bars. my ac pro pegs do away with the mount to the heal cage
I made a bracket out of 1/8 steel and it hasn't broke yet, I also removed the rear brackets above the exhaust, not sure if that helped or not
I have broken so many of those brackets its not even funny! I welded a piece of flat aluminum to the back of the nerfbar and bolt the fender to that.
1 - 9 of 9 Posts
