I'm not real mechanically inclined but I'm learning more and more owning this 2006 Brute. Is there any videos or step by step instructions on removing the rear diff? I can't find anything on youtube.
Not that tough. Drain the oil first. Then collaps and remove the drive line, remove both axles (you can take the a-arms off and leave the knuckle attached if you wish). Remove the brake cables and vent tube. Then just remove the mounting bolts and work it out.
