I have a few lose screws holding plastic. They won't tighten back up. The screw heads round out. Do you grind them off with a cutoff blade? Do you spray the plastic with water to keep from melting? Thanks
screws
get a impact driver they will come out they are not real expensive either you need 1 when you work on bikes 4 wheelers etc
