1 - 8 of 8 Posts
just wondering how to replace the output shaft in my transmission on my lakota. i have the cover off right now and it looks as if i gotta take the engine out and split the case. is this correct?
I may be in the same boat as you. Did you have to split the case and if so, how hard was the process of doing it?
Thanks guys for the respose and the Manual.. Greatly appreciated.
I just bought this Lakota a few days ago for a great price ($400) and it already had 4 new tires, Battery, new chain and Sprockets and brakes all around..
I dont mind having to put some money into it as long as it will not break the bank..
Thanks again...
Mark
Not a bad deal at all! I got mine for 400 with broken plastics and a warped head. I put a new sprocket on because the old one was bent and got the cylinder and head planed for 50 bucks and she was good to go. I had to take that side cover off and ended up messing up and oil seal so now i have a leak around the shifter, so that is something you may want to watch out for.
1 - 8 of 8 Posts
