I use the royal purple because its easy to come by at the local auto parts store. Make sure you use kawie wet brake oil in the rear diff.
Where in md are you?
Thanks for the input.I use the royal purple because its easy to come by at the local auto parts store. Make sure you use kawie wet brake oil in the rear diff.
If you are going to up grade the air filter go with the twin air pro cage. You will need to rejet if you do this though. The stock is restrictive with the screen in. If you are just trail riding keep it stock and simple. Plenty of good hrs left on that machine. You might want to check the valves some time.[/QUOTE
hey, i have an 09 brute and i just put a K&N air filter in it, i noticed u talked about the stock screen being in, i dont know if the 2 machines are at all alike in the air box but are u talking about the metal screen that lays down inside the filter across the bottom of the air box and if soo should i remove it?
