1 - 19 of 19 Posts
What is the tallest riser I can use on my 08 BF750, and not have to change control cables????
Can I use a 3" rise without any changes?????
Thanks, MV
Discussion Starter #2
No one here uses ROX risers on their BF750??????
Thanks for the help guys. Now, I need to find a deal on the Rox Risers
You can use the 3.5" risers but not with the stock bars. Add a set of lower aftermarket bars and the total height difference will be about 2.25". You may have to re-route a few cables and make sure your throttle doesn't come on when you turn your bars.
I have a set of the ROX 3 1/2" 7/8 x 1 1/8 Riser's, you can have them for $50 Including Shipping.
Does anyone have any pictures of the kit installed. Been thinking about this set up for my 09 750. Looking at the one on the specials page for 169. or something similar.
Discussion Starter #10 (Edited)
I am interested. Please send pix. I PM'd you my email addy
Mikey
The ROX riser's I have are for the "Fat Bar", here is what I am including and Mikey V has 1st crack at it.(( No Handlebars ))
With the CR High bend Fat Bar, 3.5" ROX Riser, the handlebar is right where it needs to be on the Brute Force 750. The CR High Bend has a real comfy feel to them, easy on the wrist/arms and your shoulders.
I had the CR High Bend Fat Bars Pro-Tapers with 2" Rox Risers mounted on my short owned Bomb 800, a must-do upgrade. Here is a Pic of the Pro-taper CR High bend w/2" ROX risers on the Bomb 800, these Pro-Taper Handlebars/2" Rox riser's were sold to a Bomb 800 buddy.
Discussion Starter #12
I will take them. I PM'd my email addy yesterday. I can pay instantly; if you take PayPal
Reviving a dead thread, but back to the original question that was never answered. Are 3.5" risers truly as far as you can go, even with low bend bars? I was considering using 5" Rox risers on my 750 Brute with low bend Trail Tech X-bars. Is that going to be a problem?
I called Rox before I ordered mine, they said that I could do 5" without changing any cables but suggested not using them. I am running 3.5" with CR bend Tag Alius bars.
Are you happy with your's, or would you prefer them to be a little taller?
Thanks, guess I'll go with the 3.5" ones too.
The best part about it isn't necessarily even the height. You can rock the bars back-and-forth to whatever angle you like and you can also tilt the risers forward or back to give you a further or shorter reach. It essentially makes them multi way adjustable.
1 - 19 of 19 Posts
