1 - 9 of 9 Posts
I recently bought a LM-2 and the RPM inductive clamp. I need to know what the RPM pulse is on are V-twins. Right now it's at whatever Innovates stock settings are. I think it's at like 05 or .5 then there is options to change the pulse to 1,2,or 3
I have the LM-2 hooked to my 665 right now and its telling me im redlining at 10,300 RPM this can't be right. So I figured I need to change the pulse. Thanks
I could really use some help here guys. Innovate is closed so I can't get through to them. I changed the pulse on the lm-2 to 2 or 2.5 cant remember and now it says my 665 is idling at 600 rpm's
would like to help, however dont even understand the question in the 1st place!!
Code:
understand that as a clamp to pick up on spark plug pulse,and inductive would mean works with a coil!!
Code:
have no idea what is meant hear!!
Code:
pls educate me !!
maybe others also dont understand the question
:D
I'm not even sure I understand either. I'll just wait for Innovate to get back in and I'll call there tech support. Thanks anyways guys.
Did you try the different settings until you find one that reads the max RPMs are close to 8500 rpms or less (if using a stock cdi)? That is what I would do.
Discussion Starter #7
Well I have a 665 with fst cams, custom Muzzy, Dyna CDI, and stage 2 spider VFJ clutch. I think my rev's are going to be higher then 8,500.
The Dyna (non-programmable) have a 9200 rev limiter on it. Even so, I seriously doubt that you will ever hit that rev limit...I never have and I have the FST 800 kit. Again, try different settings until you find the one that is around 8500 (give or take) and that should be the right one.
Discussion Starter #9
Alright I'll give that a try. I appreciate your info.
1 - 9 of 9 Posts
