Here are your clutch sheaves, spring, weights, and the Dalton I did a face cut on underneath by the back of the bushing to .100. I also replaced the moveable sheave bushing and the two bolt guide hollow dowel pins and balanced them. Installed new shoes on this spider and set clearance. Non- rotationally balanced all the parts. Installed new belt after washing it in warm water. Cleaned sheaves with electro contact cleaner and wiped dry.
https://www.youtube.com/watch?v=mOl5IBE3SAo&feature=youtu.be
What can any of you tell me from this video. Did I miss or over look anything? I am trying to get it together for a ride when I get off hitch and I put it together with not much sleep.
Thanks...
It was hard to see any details from a picture and video.
The belt looked a little tight in the picture; there wasn't any excess squealing in gear at an idle?
Discussion Starter · #4 · (Edited)
Nah, it had spot on deflection on the tight side, within limits, but it's new and should stretch. I'm used to having another person, usually a tech, look for anything obvious before closing up as a safety precaution. Its how we negotiate fatigue and complacency. Thank you for your time Nova.
I should add, the balance work I did smoothed out alot of the vibration. I hardly even feel it running. That made me happy happy happy ?
