Hi I have a 2005 prairie 700 and its stuck in 4wd the indicator says 2wd, Ive looked up the parts and found the acutator but is there a electrical relay that could be bad?
could be your switch on the handlebars too. is it not flashing?
typically if its an electrical issue like the 4wd actuator or the ecu it will cause your dash to flash back and forth from 2wd-4wd meaning (one of the electronic units is bad).. with the dash not flashing it almost sounds like something might be wrong inside your front diff... typically when the dash IS flashing its either your 4wd actuator or your kebc actuator...
have you checked your fuses under the seat as well?
