Hey guys, i went ahead and finally bit the bullet to replace the front upper a arm and convert to poly bushings. Going to drill and tap grease fittings. I then realized that my ball joints were shot so i just purchased some, and then i thought while i had it apart go ahead and change wheel bearings (seem ok but has almost 500 hours on it so i thought i might as well plus ride in water alot)
Last time i changed my front diff oil it was like a milkshake (like i said i understand, i ride in alot of water where it submerged often). Should i be replacing my axle seals as well? It always gets some water in it but last time was bad, had to use diesel to get it all out. I never see a leak on the floor or on the machine.
Just was looking for some thoughts. Thanks
I would change the axle seals and the front pinion seals.
While you are there, check the breather tube for the diff to make sure it is not dry rotted or cracked open.
  • Like
Reactions: kickstart
