1 - 10 of 10 Posts
Skat Trak 10 Paddle Extremes, ITP Wheels $270 Shipped
These are off of my 06 KFX 700. Tires are triple buffed and there is no size on the tires. They measure almost 24" tall from paddle to paddle. They are on 9X9 ITP wheels. There is very little wear on these. Only driven on pavement to get from camp site to gate at Little Sahara.
Sold my VForce and don't need them any more.
Wish i would have waited i have a set that fits a bf750 i have to redrill...If I could sell these I would take yours.
bump to top
Those are 10x8 ITP wheels, not 10x10's.
What would the size be expressed in the typical manner. ie. 25x12x10. Hard to know with the sidewalls being buffed.
I am guessing if they are almost 24" to the paddle tips, they are 22x11-10 on 10x8 wheels.
Discussion Starter · #8 ·
The wheels measure 10 inches in total diameter and 4.5 inches from the center to the inside and 6 inches from the center to the outside. So actual measurements are 10x10.5.
OK, they are not what I had guessed but the way you measured them isn't correct. Those are 9x9 wheels then and probably a 22x11-9 tire. A 10" diameter wheel will measure closer to 11" if you measure all the way to the outer lip of the wheel. The same thing is true for the width. Wheels are actually measured for diameter and width at the bead area right where the tire beads sit (see attached pic). ITP never made a 10x10 wheel with the Kawie 4x137mm rear bolt pattern.
Discussion Starter · #10 ·
Thanks for the info. $250 Shipped!
1 - 10 of 10 Posts
