1 - 9 of 9 Posts
I'm gonna take a stab at doing one on Saturday. I'm not looking to get into in hardcore cause its just not big down here in Florida. My question is which tires would work best. A set of stockers or I have a set of holeshots? If holeshots, would it be better to turn them around backwards? Any info is appreciated.
Jason
Really depends on the surface, some are loose or sandy soil, some are packed clay, likely the holeshots will do the best, if you posted the rules on here im sure some people will help you with your set up
If the Holeshots are new or in as new condition, run them normally. If the leading edges are worn or rounded off, either sharpen them or run them backwards. You might consider running the rear stockers on the front as well to add some footprint.
As Riverkid said, what are the rules?
What Kawi do you own?
I would take the air down some in the tires. Somewhere around 4 lbs.
1 - 9 of 9 Posts
