If you can run your fuel screw all the way in without it dying, then your pilot is to big. Once you get it to bog when running it in and then die just before seated, then your pilot should be dead on and you should be able to set the fuel screw at 2 to 2.5 turns out. I am assuming you both are running the FCR, so check to see if the hot start or block off cap is secure as well as the choke pull. Another thing to look at, IF it was running correctly prior to these issues, then have a look at your valve clearances. It will make it hard to start when warm if they are out of spec.
