Can't remember how many down to go. I thought 2 but could only get 8's today. Stock is cr7's will 8's work for a 300' spray? Or do I need to go 9's.
Thanks
I run 9's
I was thinking that. Thanks
Run 8's or 9's with a slightly smaller gap. The bigger nitrous shot requires a colder plug, shorter ground strap and less gap. If you add a better ignition system, you can open the plug gap back up a bit.
Thanks Camo. I'll put some 9's in when I can.
