Spark plugs
10K views 13 replies 7 participants last post by  riverkid
If you have not done the plug boot mod you need the cr7e resistor plug. If so, use the cr7eb non resistor.
The CR7E vs CR7EB is not resistor vs non-resistor. They are identical except the CR7EB already has the correct tip for the boots used with the plug wire mod.
Sent from my XT907 using Tapatalk 2
Interesting, I always get the eb's because they are actually a tad cheaper at Advance and I dont have to mess with the tips.
I found the same thing and I like the solid tip rather than a threaded on aluminum piece. I think they are a common plug for motorcycles.
