Hey guys newbie here can you tell me what to look for on my 86 bayou? When I push the start button I can hear the starter turning but the engine isnt. The chain was replaced last year so what could it be. Thanks
I think you are on the right track with the chain. Could be the starter clutch as well. You will need to pull the left side case to be sure. Have something to catch oil when you do, even if you drain the oil there will still be some inside that case.
Jim
Cam chain runs behind starter chain. Flywheel will have to come off to reach starter clutch. Think that if you pull the starter you could more than likely get the starter chain off,while leaving flywheel on. You are gonna need a flywheel puller. Your best bet would be a Clymer manual.
Jim
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Kawasaki ATV Forum
