The design was changed enough that the non-eps units don't have a place to put one but if there is at least 2"s of open space on the stem and you are able to fabricate a special bracket to the frame, you may be able to adapt any of the "stick" type damper to it. Of course of you have a EPS system you are SOL but shouldn't need it.
I have a 2018 750 with a 11 position adjustable stick type damper on it and it works very well. I purchased it from Dennis Kirk for $180.I've been looking for what seems like weeks! I need a unit for a 2019 750 . Steering stabilizer or damper .I can't find anything.
Anyone else had any luck or know of something that works?
Ah...there you go.I have a 2018 750 with a 11 position adjustable stick type damper on it and it works very well. I purchased it from Dennis Kirk for $180.
I have no idea who Dennis kirk is? Got any idea how to contact? That would be greatly appreciated!I have a 2018 750 with a 11 position adjustable stick type damper on it and it works very well. I purchased it from Dennis Kirk for $180.
Should have just bought a brute with eps.Well ... that sucks!
So even the disc type are to large .
Also can't find an after market eps to fit..
Looks like I may have to live with it
I thought the aftermarket eps fits the newer brutes ?Well.... after thoughts huh?
But I do appreciate you piping in with that helpful info? Thanks
