1 - 10 of 10 Posts
I just finished a few cosmetic things on my V. I then rode it around the storage area but notice after a few minutes it just started to idle high. The thumb throttle seems fine but a couple of times in drive it was high. What should I look for. Here are a couple of updated pictures.
pull the cover off the throttle housing and spray in some lube. could be a binding/sticking cable.
first try starting it and turn the wheel lock to lock to see if the rpms raise up.
cable adjuster could be broken where it goes into the throttle.
theres a place to start. let us know what you find.
bike looks great! what kind of nerfs are those?
there was also a recall on the older ones for the nuts that lock the cable into the carbs loosing up.
I'll give that a try. Thanks
Discussion Starter #5 (Edited)
I'll tear it down this weekend and check for that. If you check in my thread from a week or so ago, I was looking for a particular set of nerf bars. I was told they were Rock series nerfs so I ordered these from off Ebay Kawasaki KFX700 Silver Race Nerf Bars with footpegs:eBay Motors (item 180290935323 end time Oct-23-09 06:14:27 PDT)
What I got was something totally different but I was still happy with them so I put them on. I will perhaps mod the front mounts but other than that, they are fine.
In the front, do they each attach to the frame separately or do they connect to each other under the frame---Thanks
Kenny
Banned
Mine done that, It was a bad/Frayed throttle cable!
Discussion Starter #9
Kenny
That is the downfall with these nerfs, they attach separately. I may weld a bar between the two if necessary in the future.
save yourself the pain and $$ and replace the cable mine was frayed and had a little sand on top that added to my wreck that is going to cost me way to much so it sits for a while :rolleyes:
1 - 10 of 10 Posts
