Hello again all, I've been fooling around on the bike these last couple days, figuring out what else needs to be done, to get it 100%.
The motor itself seems almost spot on, except for an intermittent popping back thru the carbs. It seems most prevalant when not completetly warmed up, and only between aprox. 1500-3000 rpm. I think this may be a low quality fuel problem, as I just dumped some in from my 5 gallon can for my mower which is regular grade, or 87 octane. The fuel light is on now so I'll fill a can with Super; 93 octane, and see if it improves before I go messing with the carbs.
My first priority however is the throttle cable, as the flexible tube is broken where it connects to the hardline 90* bend down by the carbs. It doesn't self return all the way to idle, and today, stuck @ part throttle while I was trying to brake, going around a corner. I hi-sided, turned the bike over, flew 10 feet into and thru the air, and hit the ground hard on my shoulder and head....of course I was "only taking it for a spin" so I didn't have my helmet on.
I'll be O.K. but I'm done riding it, until I get a new throttle cable. What throttle cable do you guys like? Do you run the stocker, or an aftermarket like Pro-Motion?
Thanks Ed3
Thanks Ed3
