1 - 10 of 10 Posts
Is anyone using the stock carbs on the 800 BBK with stage lll cams.
What jets are you running and what is the altitude where you live.
it's been awhile ago
i drilled the mains i believe to 3/32 that's what mickey FST said to do
use to have 45 pilot's, that was too fat, running 42's now
shimed the needles and shorten the springs, camo had a video on youtube
looks good on the air/fuel meter
200 ft
Discussion Starter #6
200 ft
I ride at 4000-5000 ft on average. So anything you are running will be way too fat for me. When my motor was stock I was running 145 mains. With the 800 I could probably start at about 150. Is your a/f running about 11:1.
I can’t get it to start. I’ve checked the valve lash and they are perfect. I don’t think chokes are working. Once it is warmed up it starts up every time.
A/F 11.5-12
Yeah mine had a hard time starting on cold mornings too, there was times i couldn't get it to start till later in the day , after it started and got it warmed up it started fine.
I didn't think the starter was spinning fast enough, So i bought a new agm battery with the highest CCA i could find that fit the battery box,i think it was like 225 CCA.
Didn't change anything still starting the same.
So I tryed a Lithium Battery 300 CCA it's a little pricey, But it did spin the motor a little faster and it always starts now on cold mornings, it 's a tiny little bastard, but it did help lol
Discussion Starter #8
Was it still starting hard with stock carbs until you got the lithium battery?
Can you give me link for that battery. Or the brand and model number.
1 - 10 of 10 Posts
