i have a carburated 750 it runs great. my problem is after it sites for a couple of days its hard to start like the fuel bleeds from the carbs back in to the gas tank even with a full tank of gas the valves are set to spec. i have to be missing something just started this not long ago. i would love some help with this one.
Does your gas tank pressurize when it heats up. Its possible after a few days the fuel will leave the carbs. Check and see if the relieve /check valve is still working on top of tank. When you unscrew the gas cap pressure should relieve. If the valve is not working you will not have gas in carbs after a few days. It evaporates.
^^you talking about the valve going into the frame? when i did my snorks i took that valve out and haven't had any ill effects but mine is also EFI
minimus thanks for the reply. i found the valve and air flows both ways through it if a good cleaning dont help a new one will i hope.
